XWAVE can perform various analyses on simulated signals. For example, for xreal-type signals, it can compute their eye diagrams, Fourier transforms, and power-spectral densities (PSD). For xbit-type clock signals, it can compute their jitter histograms and phase noise spectrums.
However, XWAVE only displays the resulting plots of the analyses. Is there a way to export their data so I can post-process them using another tool?
To address your needs, we have revised the Python API for XWAVE in the XMODEL 2024.09 Release so that you can perform the XWAVE analyses in a Python script and export their results to another tool.
Here is an example Python script that computes the power spectrum density (PSD) of a signal named 'TB.A'
stored in a JEZ-format waveform file named 'xmodel.jez'
#!/usr/bin/env xmodelpy # 0. import XMULAN and XWAVE libraries import xmulan import xwave # 1. read a signal trace from a waveform file row = xmulan.rowml().readmeas("xmodel.jez") trace = row["TB.A"] # 2. perform XWAVE analysis anaclass = xwave.psd_xreal(t_start=50e-6, f_min=0.0, f_max=1e9, window="Rectangular") result = anaclass.do_analysis(trace) psd, freq = result # 3. plot the analysis results fig = anaclass.plot_results(*result) fig.show()
After importing the XMULAN and XWAVE libraries, the script first reads a signal trace from a waveform file using the 'readmeas()'
method.
Next, it instantiates one of the XWAVE analysis classes named 'psd_xreal'
with a set of parameters, for example, defining the start time ('t_start'
), minimum frequency ('f_min'
), maximum frequency ('f_max'
), and windowing function ('window'
). It then calls the 'do_analysis()'
method of the analysis class instance to perform the analysis, which returns a set of evaluated power-spectrum density (PSD) and frequency values of the signal as the result. This result can be exported in various data formats. For example, this Q&A posting shows how to export the data in CSV format.
It is also possible to generate a plot figure using the results, by calling the 'plot_results()'
method of the analysis class instance and calling the 'show()'
method of the returned figure object.
Here is a list of the XWAVE analysis classes currently available in the XMODEL 2024.09 Release.
eyediag_xreal
: Eye diagram analysis for xreal-type signalsfourier_xreal
: Fourier transform analysis for xreal-type signalspsd_xreal
: Power-spectral density analysis for xreal-type signalsjhist_xbit
: Jitter histogram analysis for xbit-type signalspnoise_xbit
: Phase noise analysis for xbit-type signalsAnd you can print a list of supported parameter arguments and methods along with their descriptions by calling the 'print_help()'
method of each XWAVE analysis class.
$ xmodelpy -c "import xwave; xwave.psd_xreal.print_help()" ======================================== ANALYSIS psd_xreal ======================================== Power spectral density (PSD) analysis for xreal signals Supported parameters: t_start : Start Time (default: 0.0) t_stop : Stop Time (default: -1.0) f_min : Minimum Frequency (default: 0.0) f_max : Maximum Frequency (default:'1G'
) window : Window Function (choices: ('Rectangular'
,'Hann'
,'Hamming'
,'Blackman-Harris'
), default:'Hamming'
) num_freq : Number of Frequency Points (default: 400) overlap : Overlap Ratio (default: 0.5) Supported methods: result = do_analysis(trace) : perform the analysis and return result=(psd, freq) psd : array of power spectral density values freq : array of frequency values fig = plot_results(*result) : plot the analysis results
XWAVE는 시뮬레이션로 얻어진 신호 파형에 대해 다양한 분석을 수행할 수 있습니다. 예를 들어, xreal 타입의 신호에 대해서는 eye 다이어그램, 퓨리에 변환, 전력스펙트럼 밀도를 계산할 수 있고, xbit-타입의 클록 신호에 대해서는 지터 히스토그램 및 위상잡음 스펙트럼을 계산할 수 있습니다.
하지만, XWAVE은 그 분석결과를 그래프로만 보여줄 뿐입니다. 추가 분석을 수행하기 위해 그 결과 데이터를 다른 툴을 옮기는 방법이 있을까요?
method.
eyediag_xreal
,'Hann'
,'Hamming'
,'Blackman-Harris'
