Sometimes, I need to add some options to the 'xmodel'
command that are specific to our SystemVerilog simulator. The '-allowredefinition'
option for the NC-Verilog command 'ncverilog'
or 'irun'
can be such an example. I know the 'xmodel'
command supports standard options such as '-f'
for providing a command file input and '-D'
for defining a macro. But sometimes I need to pass some special options to the SystemVerilog host simulator that are not supported by the 'xmodel'
command. Is there a way?
Yes, you can pass the simulator-specific options to the 'xmodel'
command using the '--elab-option'
or '--sim-option'
options. The 'xmodel'
command runs each simulation job in two steps, elaboration and simulation. And with the '--elab-option'
and '--sim-option'
options, you can pass additional options to each simulator command performing the respective step. For information on the simulator commands issued by the 'xmodel'
command, please refer to this Q&A posting.
For example, let's say you want to pass an '-allowredefinition'
option to 'ncverilog'
during its elaboration step. For your information, this option allows redefinition of the same-named module. You can add this option by enclosing it within the '--elab-option'
and '--'
tokens, as shown below:
xmodel tb.sv --top tb --simtime 10ns --sim ncverilog --elab-option -allowredefinition --
As another example, let's say you want to pass a '-gdb'
during its simulation step. This option runs the simulation under the 'gdb'
debugger. This time, you can add this option by enclosing it within the '--sim-option'
and '--'
tokens:
xmodel tb.sv --top tb --simtime 10ns --sim ncverilog --sim-option -gdb --
Please note that you can also pass vendor-specific options made of multiple tokens by listing them between the '--elab-option'
and '--'
tokens or between the '--sim-option'
and '--' tokens. Here is an example of passing '-allow redefinition'
and '+ncerror+CUVMPW'
options to the elaboration command and passing '-gdb'
option to the simulation command:
xmodel tb.sv --top tb --simtime 10ns --sim ncverilog --elab-option -allowredefinition +ncerror+CUVMPW -- --sim-option -gdb --
You can check whether the options are being supplied as intended with the '--command'
option, which displays the commands and options issued by the 'xmodel'
command:
xmodel tb.sv --top tb --simtime 10ns --sim ncverilog --elab-option -allowredefinition +ncerror+CUVMPW -- --sim-option -gdb -- --command
'xmodel'
명령을 사용할때 특정 SystemVerilog 시뮬레이터에서 지원하는 옵션을 추가하고 싶을때가 있습니다. 예를 들면, NC-Verilog의 'ncverilog'
또는 'irun'
명령의 '-allowredefinition'
같은 옵션을 들 수 있겠습니다. 'xmodel'
명령이 커맨드 파일 입력을 지정하는 '-f'
옵션이나 매크로를 정의하는 '-D'
옵션 등의 표준 옵션들은 자체 지원하는 것을 알고 있지만, 가끔은 특정 SystemVerilog 시뮬레이션에서 지원하는 옵션들을 사용해야 하는 경우가 있습니다. 이들을 추가하는 방법이 있나요?
or '--sim-option'
and '--sim-option'
and '--'
and '--'
tokens:
and '--'
command:
