After reading the chapter on "Automating simulations with XMULAN and Python" included in the MODELZEN tutorial, I wrote a Python script listed below that runs a SPICE simulation on a MOSFET transistor and plots its Ids vs. Vgs graph. The problem is, I want to plot the y-axis of the graph in log scale, but I cannot find any information about the plot()
function highlighted in red below.
Where can I find more details about this plot()
function and other functions included in the XMULAN package?
#!/usr/bin/env xmodelpy
from xmulan import mulan, rowml
import pylab
M = mulan()
M.new_sw(vdd=[0.1,1.2])
for row in M.sw_iter():
runbase = row.hspice("mos_vgid.empy")
row.readmeas(runbase + ".sw0")
row['v:vg':'i:mn'].plot()
pylab.show()
XMULAN is a Python library, and just like any other Python libraries, it has a built-in, on-line documentation. You can access its documentation either by using the xpydoc
utility from the Linux command line or by using the help()
function from the Python shell.
For instance, the plot()
function you are inquiring is one of the methods of a waveform
class defined in the xmulan
module. To access its documentation, you can run the following command on the Linux command line:
$ xpydoc xmulan.waveform.plot
Or, you can run the following commands on the Python shell:
$ xmodelpy
>>> import xmulan
>>> help(xmulan.waveform.plot)
These commands show the documentation on the plot()
method:
Help on method plot in xmulan.waveform: xmulan.waveform.plot = plot(self, filename=None, plotfunc=None, use_line=True, use_marker=True, use_legends=True, **plotargs) unbound xmulan.waveform method plot the waveform data and save it to a file if filename is specified. e.g. wf.plot(filename="plot.png") wf.plot(plotfunc=pylab.loglog)
As for your question, you can plot with a log-scale y-axis by providing pylab.semilogy
as the plotfunc
argument as illustrated below. For more information on the plot functions available from the pylab
module of the matplotlib
package, you may find this link useful.
import pylab
M = mulan()
row['v:vg':'i:mn'].plot(plotfunc=pylab.semilogy)
pylab.show()
MODELZEN 튜토리얼에 포함된 "Automating simulations with XMULAN and Python" 장을 읽고 MOSFET 트랜지스터에 SPICE 시뮬레이션을 수행한 후, 그 결과로 Ids 대 Vgs 그래프를 그리는 Python 스크립트를 아래와 같이 작성해보았습니다. 문제는, 그래프의 y축을 log 스케일로 만들고 싶은데, 빨간색으로 표시한 'plot()'
함수에 어떤 인자를 사용할 수 있는지에 대한 정보를 찾지 못하였습니다.
이 'plot()'
함수와 XMULAN 라이브러리의 다른 함수들에 대한 좀더 자세한 정보를 어디서 찾을 수 있나요?
import pylab
M = mulan()
pylab.show()
$ xmodelpy
>>> import xmulan
method:
as the plotfunc
import pylab
M = mulan()
pylab.show()
