Is there a way to probe the currents flowing through circuit primitive instances such as nmosfet, pmosfet, resistor
and capacitor
Basically, you can access the voltage, current, and instantaneous power of each circuit primitive instance via its internal variables named V, I, and P. For instance, the current flowing through a resistor instance named R1 can be accessed via R1.I and you can record its waveform by dumping R1.I. One way to achieve this is to add "R1.I" to the list of variables to be dumped, either by defining the "Variables" property of the dump primitive instance in GLISTER or by supplying the variable list to the $xmodel_dumpvars()
command as shown below. Note that in this case, the name "R1.I" must be a valid Verilog hierarchical name from the location it is used.
initial begin $xmodel_dumpfile("xmodel.jez"); $xmodel_dumpvars(R1.I); end
In case you want to probe currents of multiple circuit primitive instances, you can provide a "probe" option to the dump primitive in GLISTER or to the $xmodel_dumpvars()
command. For instance, adding
probe=resistor.I
in the "Extra Options" field of the dump primitive in GLISTER as shown below, or calling the $xmodel_dumpvars()
with the following option:
$xmodel_dumpvars("probe=resistor.I");
would dump the current waveforms of all the resistor instances located in the current hierarchy and below.
If you want to probe the currents of other circuit primitive instances such as mosfet
, pmosfet
, and capacitor
as well, you can simply list the items delimited by commas (,):
probe=resistor.I,capacitor.I,nmosfet.I,pmosfet.I
It is also possible to combine this option with the other dump options. For instance, additionally defining the "Depth Level" field to 1 or using the following $xmodel_dumpvars()
command,
$xmodel_dumpvars("level=1", "probe=resistor.I");
would instruct XMODEL to dump the current waveforms of the resistor instances located in the current hierarchical level only.
Starting from 2020.11 release, you can probe the currents of all types of circuit primitive instances at once by providing the "probe=*.I"
option to the dump
primitive or to the $xmodel_dumpvars()
command. That is, you can add
probe=*.I
in the "Extra Options" field of the 'dump'
primitive in GLISTER, or call $xmodel_dumpvars()
with the same option
$xmodel_dumpvars("probe=*.I");
to probe the currents of all types of circuit primitive instances in the design.
