Is it possible to automatically switch the FSDB waveform file being generated by the $xmodel_dumpfile()
command to a new one when its size reaches a certain limit?
Yes. Starting from XMODEL Release 2018.12, you can use a "sizelimit="
option with the $xmodel_dumpfile()
command to automatically switch the output waveform file when its size reaches a specified limit. This "sizelimit="
option specifies the limit of each file size in MegaBytes.
For instance,
$xmodel_dumpfile("xmodel.fsdb", "sizelimit=", 20);
will generate a series of files as named below whenever the current file size reaches 20MB.
xmodel_000.fsdb xmodel_001.fsdb xmodel_002.fsdb ...
