I have a model that selects one from multiple frequency values as controlled by digital inputs. When I described the model using a set of switch
primitives in parallel, I found the simulation became rather slow with many events generated. Why is that?
The problem is not with the switch
primitives; it is with the very large input values you are feeding the switch-based multiplexer with. They are MHz range, larger than 1,000,000.
When XMODEL simulates circuit-level models like this one using switch
primitives, it tries to suppress the occurrences of large numbers as they may result in loss of information contained in small numbers when they are combined together (e.g. adding a large number to a small number). In this case, XMODEL generates additional events to avoid such information loss.
One way to get around the problem is to feed scaled-down inputs to the switch-based multiplexer and scale the output up later using a scale
primitive. The simpler way is to use a select
primitive instead of the switch
primitives, which is a function primitive that directly models an analog multiplexer.
