vsource :
A voltage source circuit element.
The vsource
primitive represents a voltage source stand-alone or controlled by an input signal across two circuit terminals. Note that this primitive is a pseudo-module to describe a structural netlist of electrical circuits and not a behavioral model by itself. The XMODEL simulator extracts an event-driven behavioral model at run-time based on the circuit network described by these circuit-level pseudo-modules.
The vsource
primitive can be used in two different ways: first as a dependent voltage source controlled by an xreal-typed signal from a signal-flow model (mode=”in”) and second as an independent voltage source supplying a constant DC voltage (mode=”dc”).
1) A dependent voltage source controlled by an input (mode=”in”)
The default behavior of the vsource
primitive (mode=”in”) is to drive a voltage controlled by the input signal in
between two circuit nodes. For instance:
xreal in, A, B; sin_gen #(.amp(5.0), .freq(30.0)) in_ac(in); vsource vin(.pos(A), .neg(B), .in(in));
es a 5V-amplitude, 30Hz AC voltage between A and B.
This primitive provides a way to create a wide variety of voltage sources by combining it with various stimulus generator primitives. In other words, the primitive vsource
serves as a gateway that propagates a signal from signal-flow models to a voltage in electrical models.
2) An independent voltage source supplying a DC voltage (mode=”dc”)
When the parameter mode
is set to “dc”, the primitive works as an independent DC voltage source. For instance:
xreal A, B; vsource #(.mode("dc"), .dc(5.0)) vin(.pos(A), .neg(B), .in(`ground));
connects a 5.0V supply between A and B. The terminal connected to the port “in” is ignored. In fact, it is equivalent to:
xreal in, A, B; dc_gen #(.value(5.0)) in_dc(in); vsource vin(.pos(A), .neg(B), .in(in));
pos | input | xreal | positive terminal |
neg | input | xreal | negative terminal |
in | input | xreal | input control signal |
mode | string | “in” | None | mode of operation |
dc | real | 0.0 | volts | DC voltage value |
