diode :
A diode circuit element.
The diode primitive represents a two-terminal diode. Note that this primitive is a pseudo-module to describe a structural netlist of electrical circuits and not a behavioral model by itself. The XMODEL simulator extracts an event-driven behavioral model at run-time based on the circuit network described by these circuit-level pseudo-modules.
The diode primitive can model diodes in three ways: using an ideal model (ideal),  exponential model (exp), or piecewise-linear model (pwl).
1) Ideal diode model (model = ‘ideal’)
The diode turns on when the voltage across the two terminals (pos and neg) is higher than the specified turn-on voltage (Von) and turns off otherwise. The parameters Ron and Roff define the turn-on and turn-off resistances, respectively.
2) Exponential diode model (model = ‘exp’)
The diode current (Id) is an exponential function of the voltage (Vd = V(pos) – V(neg)) according to the following equation:
    Id = Is * (exp((Vd-Id*Rs)/(N*VT)) - 1)
    where VT = kT/q (25.695mV at 25C)
In this equation, Is and VT change with the global parameter `global_temp, defining the temperature in Celsius (default: 25C). Specifically, the thermal voltage VT is proportional to the absolute temperature and the transport saturation current Is is proportional to exp(-VG0/VT), where VG0 is assumed to be 1.205V for silicon.
The parameters abstol and reltol set the error tolerance approximating these equations.
3) Piecewise-linear diode model (model = ‘pwl’)
Using this model, the diode can have an arbitrary piecewise-linear I-V characteristic. In this case, the diode is equivalent to a nonlinear resistor (the res_var primitive). The parameter R_data describes the piecewise-constant resistance values across different voltage intervals, using the same format as the R parameter in the res_var primitive.
For all the diode models, the parameter C defines the linear capacitance across the terminals and the parameters Cpos and Cneg define the linear capacitance of the terminals pos and neg to the ground, respectively.
| pos | input | xreal | positive terminal |
| neg | input | xreal | negative terminal |
| model | string | “ideal” | None | diode model |
| Von | real | 0.0 | volts | turn-on voltage |
| Ron | real | 0.01 | volts | turn-on resistance |
| Roff | real | `INFINITY | volts | turn-off resistance |
| Is | real | 1e-16 | ampere | saturation current |
| N | real | 1.0 | None | emission coefficient |
| Rs | real | 0.0 | ohms | series resistance |
| abstol | real | 1e-9 | A | absolute tolerance |
| reltol | real | 0.1 | None | relative tolerance |
| R_data | real array | ‘{1.0} | ohms | PWC resistance |
| C | real | 0.0 | farads | pos-to-neg capacitance |
| Cpos | real | 0.0 | farads | pos-to-gnd capacitance |
| Cneg | real | 0.0 | farads | neg-to-gnd capacitance |
| m | real | 1.0 | None | multiplicity factor |
