xreal_to_bit :
An xreal-to-bit connector.
The xreal_to_bit
primitive converts an xreal-type signal to a bit-type signal. The analog level of the input signal is converted to a digital level using the threshold parameters: threshold, thres0, or thres1.
The parameter threshold
sets the threshold level between logic 0 and logic 1. In other words, the output changes to logic 1 when the input rises above this threshold and to logic 1 when it falls below the threshold. The parameter strength
defines the driving strength of the bit-type output signal (e.g. 4 for weak
, 5 for pull
, 6 for strong
, and 7 for supply
In addition, by defining the parameters thres0
and thres1
, one can set different thresholds for logic 0 and logic 1 (NOTE: not yet implemented).
out | output | wire | bit-type output |
in | input | xreal | xreal-type input |
threshold | real | 0.5 | None | threshold level |
thres0 | real | `NAN | None | threshold level for logic 0 |
thres1 | real | `NAN | None | threshold level for logic 1 |
strength | integer | 6 | None | driving strength (0~7) |
width | integer | 1 | None | connector bit-width |
