xbit_to_real :
An xbit-to-real connector.
The xbit_to_real primitive converts an xbit-type signal to a real-type signal. The digital level of the input signal is converted to an analog level, defined by the conversion level parameters: level0 and level1. The output signal makes instantaneous transitions with zero rise/fall times.
The parameter delay specifies the inertial delay of the primitive. In other words, if a new input event arrives before the previous event propagates to the output, the previous event will be cancelled.
The parameters valueX and valueZ define the mapped values of logic X and logic Z, respectively. For example, if valueX is set to 0, all input values corresponding to logic X are treated as logic 0. Note that by default, the primitive ignores the logic X and logic Z values of the input and retains the last output value.
| out | output | real | real-type output |
| in | input | xbit | xbit-type input |
| level0 | real | 0.0 | None | conversion level for logic 0 |
| level1 | real | 1.0 | None | conversion level for logic 1 |
| delay | real | 0.0 | seconds | propagation delay |
| valueX | logic | 1’bx | None | mapped value of logic X |
| valueZ | logic | 1’bz | None | mapped value of logic Z |
