real_to_xreal :
: A real-to-xreal connector.
The real_to_xreal primitive converts a real-type signal to an xreal-type signal. The primitive can also perform event filtering. That is, output events are suppressed when the input change is less than the absolute tolerance (parameter abstol). Additional low-pass filtering can be applied to the input change, where the parameter delay determines the time constant of this filter.
| out | output | xreal | xreal-type output |
| in | input | real | real-type input |
| abstol | real | 0.0 | None | absolute tolerance for event filtering |
| delay | real | 0.0 | seconds | delay for event filtering |
