probe_xreal :
A probe for an xreal-typed signal.
The probe_xreal
primitive records the waveform of an xreal-typed signal into a file.
The parameter filename
sets the name of the waveform file, of which extension determines the waveform format (e.g. “.jez” for JEZ and “.fsdb” for FSDB). When recording in JEZ format, the parameter format
defines whether the data are recorded in a binary (“jezbinary”) or ascii (“jezascii”) format. When recording in FSDB format, the parameters abstol
and reltol
set the error tolerance of recording the true waveform as an approximate piecewise-linear waveform. The parameters start
and stop
define when the recording begins and ends, respectively.
in | input | xreal | signal to record |
filename | string | “xmodel.jez” | None | output filename |
format | string | “jezbinary” | None | format version |
start | real | 0.0 | seconds | abs. time to start recording |
stop | real | -1.0 | seconds | abs. time to stop recording |
abstol | real | 1e-4 | None | absolute tolerance |
reltol | real | 1e-2 | None | relative tolerance |
