probe_xbit
probe_xbit :
A probe for an xbit-typed signal.
The probe_xbit primitive records the waveform of an xbit-typed signal into a file.
The parameter filename sets the name of the waveform file, of which extension determines the waveform format (e.g. “.jez” for JEZ and “.fsdb” for FSDB). In case of recording in JEZ format, the parameter format defines whether the data are recorded in a binary (“jezbinary”) or ascii (“jezascii”) format. The parameters start and stop define when the recording begins and ends, respectively.
in input xbit signal to record
filename string “xmodel.jez” None output filename
format string “jezbinary” None format version
start real 0.0 seconds abs. time to start recording
stop real -1.0 seconds abs. time to stop recording
« probe_value
probe_xreal »
