probe_period
probe_period :
A period probe for a clock signal.
The probe_period primitive measures the period of an xbit-typed periodic clock input (in) and records its waveform into a file. The primitive uses a clk_to_period primitive to measure the period of in.
The parameter filename sets the name of the waveform file, of which extension determines the waveform format (e.g. “.jez” for JEZ and “.fsdb” for FSDB). In case of recording in JEZ format, the parameter format defines whether the data are recorded in a binary (“jezbinary”) or ascii (“jezascii”) format. The parameters start and stop define when the recording begins and ends, respectively.
in input xbit signal to measure the period from
filename string “xmodel.jez” None output filename
format string “jezbinary” None format version
start real 0.0 seconds abs. time to start recording
stop real -1.0 seconds abs. time to stop recording
« probe_freq
probe_phase »
