probe_duty :
A duty-cycle probe for a clock signal.
The probe_duty
primitive measures the duty-cycle of an xbit-typed periodic clock input (in
) and records its waveform into a file. The primitive uses a clk_to_duty
primitive to measure the duty-cycle of in
The parameter filename
sets the name of the waveform file, of which extension determines the waveform format (e.g. “.jez” for JEZ and “.fsdb” for FSDB). In case of recording in JEZ format, the parameter format
defines whether the data are recorded in a binary (“jezbinary”) or ascii (“jezascii”) format. The parameters start
and stop
define when the recording begins and ends, respectively.
in | input | xbit | signal to measure the duty-cycle from |
filename | string | “xmodel.jez” | None | output filename |
format | string | “jezbinary” | None | format version |
start | real | 0.0 | seconds | abs. time to start recording |
stop | real | -1.0 | seconds | abs. time to stop recording |
