probe_bit :
A probe for a bit-typed signal.
The probe_bit primitive records the waveform of a bit-typed signal into a file.
The parameter filename sets the name of the waveform file, of which extension determines the waveform format (e.g. “.jez” for JEZ and “.fsdb” for FSDB). In case of recording in JEZ format, the parameter format defines whether the data are recorded in a binary (“jezbinary”) or ascii (“jezascii”) format. The parameters start and stop define when the recording begins and ends, respectively.
| in | input | bit | signal to record |
| filename | string | “xmodel.jez” | None | output filename |
| format | string | “jezbinary” | None | format version |
| start | real | 0.0 | seconds | abs. time to start recording |
| stop | real | -1.0 | seconds | abs. time to stop recording |
