probe_ber :
A probe for measuring the bit-error rate of a data stream.
The probe_ber
primitive measures the bit-error rate of a data stream in
by comparing it either with an external reference data stream in_ref
(with mode=”ext” or “in”) or with an internal PRBS reference (with mode=”int” or “prbs”). In case of using an internal PRBS reference, the parameter length
defines the LFSR length N, generating a pseudo-random bit sequence with a length of 2^N-1. The value range of length
is 3~128 (default: 7). The primitive can also verify a parallel stream of M-bit pseudo-random sequences, where the bit-width M is set by the parameter width
The parameter trig_mode
defines whether the inputs in
and in_ref
are sampled at the positive edge (1), negative edge (-1), or both edges (0) of the input clk
. By default, the inputs are sampled at the negative edge of clk
(-1), assuming the data transitions are aligned with the positive edges of clk
The parameter filename
sets the name of the waveform file, of which extension determines the waveform format (e.g. “.jez” for JEZ and “.fsdb” for FSDB). In case of recording in JEZ format, the parameter format
defines whether the data are recorded in a binary (“jezbinary”) or ascii (“jezascii”) format. The parameters start
and stop
define when the recording begins and ends, respectively.
in | input | xbit | input data |
in_ref | input | xbit | reference data |
clk | input | xbit | clock |
filename | string | “xmodel.jez” | None | output filename |
format | string | “jezbinary” | None | format version |
start | real | 0.0 | seconds | abs. time to start recording |
stop | real | -1.0 | seconds | abs. time to stop recording |
mode | string | “ext” | None | reference source |
length | integer | 7 | None | reference LFSR length |
width | integer | 1 | None | input bit-width |
trig_mode | integer | -1 | None | triggering mode |
