or_xbit :
A multi-input OR gate with xbit-type input/output’s.
The or_xbit
primitive models a multi-input OR logic gate with xbit-typed signals. It is suitable for processing digital signals of which precise timing information must be preserved.
The input to the or_xbit
primitive is an xbit array, of which length is specified by the parameter num_in
The propagation delay of the logic gate is specified by the parameter delay
. The implemented delay is inertial
, meaning that if a new input event arrives before the previous input event propagates to the output, the output event will be overriden with the one corresponding to the new input event. If a transport delay behavior is desired, use the delay_xbit
primitive instead.
out | output | xbit | output signal |
in | input | xbit | input signals |
num_in | integer | 2 | None | number of inputs |
delay | real | 0.0 | seconds | propagation delay |
