nand_xbit
nand_xbit :
A multi-input NAND gate with xbit-typed input/output’s.
The nand_xbit primitive models a multi-input NAND logic gate with xbit-typed signals. It is suitable for processing digital signals of which precise timing information must be preserved.
The input to the nand_xbit primitive is an xbit array, of which length is specified by the parameter num_in.
The propagation delay of the logic gate is specified by the parameter delay. The implemented delay is inertial, meaning that if a new input event arrives before the previous input event propagates to the output, the output event will be overriden with the one corresponding to the new input event. If a transport delay behavior is desired, use the delay_xbit primitive instead.
out output xbit output signal
in input xbit input signals
num_in integer 2 None number of inputs
delay real 0.0 seconds propagation delay
« mux_xbit
nor_xbit »
