CBL_TwosCompToSignMag
CBL_TwosCompToSignMag : A combinational logic converting a two’s complement to a sign-magnitude representation
This model describes a combinational logic converting a two’s complement to a sign-magnitude. For an N-bit binary number in[N-1:0], the sign-magnitude representation uses the MSB in[N-1] as the sign bit and the rest in[N-2:0] as the magnitude. Note that -2^(N-1) in two’s complement representation will be converted to a zero in sign-magnitude representation.
module CBL_TwosCompToSignMag #(
    parameter width = 4             // bit width
    input [width-1:0] in,           // input bits
    output [width-1:0] out          // output bits
assign out = (in[width-1]) ? ~{1'b0, in[width-2:0]} + 1 : in;
endmodule
in [width-1:0] input wire input bits
out [width-1:0] output wire output bits
Name Type Default Description
width integer 4 bit width
tb_check : A testbench for checking the basic functionality of a combinational logic
This testbench checks the basic functionality of a combinational logic by enumerating all the possible input values and listing its corresponding outputs.
module tb_check ();
parameter in_width = 4;
parameter out_width = in_width;
reg [in_width-1:0] in;
wire [out_width-1:0] out;
CBL_TwosCompToSignMag #(.width(in_width)) DUT (.in, .out);
initial begin
    in = 0;
    repeat ((1 << in_width) - 1) begin
        #(1ns);
        in = in + 1;
    end
end
always @(out) begin
    $display("IN: %b --> OUT: %b", in, out);
end
endmodule
