CBL_OneHotToBinary : A priority encoder logic converting a one-hot code to a binary code
This model describes a combinational logic converting a (2^N)-bit one-hot code to an N-bit binary code. In case more than one input bits have a value of 1, the model functions as an priority encoder. For example, the model converts an 8-bit input to a 3-bit binary-coded output following the patterns below:
8'b00000001 --> 3'b000 8'b0000001x --> 3'b001 8'b000001xx --> 3'b010 8'b00001xxx --> 3'b011 8'b0001xxxx --> 3'b100 8'b001xxxxx --> 3'b101 8'b01xxxxxx --> 3'b110 8'b1xxxxxxx --> 3'b111
where x
denotes a don’t-care bit.
module CBL_OneHotToBinary #( parameter width = 4 // bit width of the binary-coded output )( input [(1<<width)-1:0] in, // one-hot-coded input output reg [width-1:0] out // binary-coded output ); int i; reg [width-1:0] _out; always @(in) begin _out = 'bx; for (i=0; i<(1<<width); i=i+1) begin if (in[i] == 1'b1) _out = i; end out = _out; end endmodule
in [(1<<width)-1:0] | input | wire | one-hot-coded input |
out [width-1:0] | output | reg | binary-coded output |
Name | Type | Default | Description |
width | integer | 4 | bit width of the binary-coded output |
tb_check : A testbench for checking the basic functionality of a one-hot-to-binary converter (priority encoder) |
This testbench checks the basic functionality of a one-hot-to-binary converter (priority encoder) by enumerating all the possible one-hot-coded input values and listing its corresponding outputs.
module tb_check (); parameter width = 4; reg [(1<<width)-1:0] in; wire [width-1:0] out; CBL_OneHotToBinary #(.width(width)) DUT (.in, .out); initial begin in = 1; repeat ((1 << width) - 1) begin #(1ns); in = in << 1; end end always @(out) begin $display("IN: %b --> OUT: %b", in, out); end endmodule
