CBL_BinaryToTherm : A combinational logic converting a binary code to a thermometer code
This model describes a combinational logic converting an N-bit binary code to a (2^N-1)-bit thermometer code. For example, the model converts a 3-bit binary-coded input to a 7-bit thermometer-coded output following the patterns below.
3'b000 --> 7'b0000000 3'b001 --> 7'b0000001 3'b010 --> 7'b0000011 3'b011 --> 7'b0000111 3'b100 --> 7'b0001111 3'b101 --> 7'b0011111 3'b110 --> 7'b0111111 3'b111 --> 7'b1111111
module CBL_BinaryToTherm #( parameter width = 4 // bit width of the binary-coded input )( input [width-1:0] in, // binary-coded input output reg [(1<<width)-2:0] out // thermometer-coded output ); int i; always @(in) begin for (i=0; i<(1<<width)-1; i=i+1) begin out[i] = (in > i) ? 1 : 0; end end endmodule
in [width-1:0] | input | wire | binary-coded input |
out [(1<<width)-2:0] | output | reg | thermometer-coded output |
Name | Type | Default | Description |
width | integer | 4 | bit width of the binary-coded input |
tb_check : A testbench for checking the basic functionality of a combinational logic |
This testbench checks the basic functionality of a combinational logic by enumerating all the possible input values and listing its corresponding outputs.
module tb_check (); parameter in_width = 4; parameter out_width = (1 << in_width) - 1; reg [in_width-1:0] in; wire [out_width-1:0] out; CBL_BinaryToTherm #(.width(in_width)) DUT (.in, .out); initial begin in = 0; repeat ((1 << in_width) - 1) begin #(1ns); in = in + 1; end end always @(out) begin $display("IN: %b --> OUT: %b", in, out); end endmodule
