step_gen
step_gen :
An analog step generator
The step_gen primitive generates an xreal-typed step signal. In other words, it generates a signal that changes from init_value to init_value+change after delay from time 0.
   init_value+change                 +-----------------------------------
   init_value         ---------------+
   time               0            delay
The primitive can also generate a pulse with finite duration when its parameter width is defined with a positive value.
   init_value+change                 +--------+
   init_value         ---------------+        +--------------------------
   time               0            delay delay+width
And the primitive can repeat this finite-duration pulse when the parameter period is defined with a positive value greater than the value of the parameter width.
   init_value+change                 +--------+            +--------+
   init_value         ---------------+        +------------+        +---- ...
   time               0            delay delay+width  delay+period
out output xreal signal output
init_value real 0.0 None initial value
change real 0.0 None step change
delay real 0.0 seconds delay
width real -1.0 seconds step pulse width
period real -1.0 seconds repetition period
« sin_gen
zero_xbit »
