prbs_gen :
A digital PRBS generator.
The prbs_gen primitive generates a pseudo-random bit sequence (PRBS) with a length of 2^N-1 to an xbit-typed output when triggered by the input trig. The LFSR length N is set by the parameter length. The valid range of length is 3~128 (default: 7).
The primitive can also generate a parallel stream of M-bit pseudo-random sequences, where the bit-width M is set by the parameter width. The parameter seq_mode defines whether the parallel stream is a MSB-first sequence (1) or LSB-first sequence (0). Its default value is 1 (MSB-first).
The parameter trig_mode defines whether the primitive is triggered by the positive edge (1), negative edge (-1), or both edges (0) of the input trig (default: 1).
| out | output | xbit | signal output |
| trig | input | xbit | trigger input |
| length | int | 7 | None | LFSR length |
| width | int | 1 | None | output width |
| seq_mode | int | 0 | None | sequence mode |
| trig_mode | int | 1 | None | triggering mode |
