poly_func
poly_func :
A polynomial function for xreal-typed signals.
The poly_func primitive defines a polynomial function for xreal-typed signals. With this primitive, one can define a nonlinear DC transfer function with upto three inputs.
The parameter num_in specifies the number of inputs, of which maximum value is 3. Depending on the value of this num_in parameter, the parameter array data defines the coefficients of the input-to-output polynomail equation as listed below:
1) For a single-input polynomial (num_in = 1):
out = data[0] + data[1]*in + data[2]*in^2 + data[3]*in^3 +
      data[4]*in^4 + ...
2) For a two-input polynomial (num_in = 2):
out = data[0] + data[1]*in[1] + data[2]*in[0] +
      data[3]*in[1]^2 + data[4]*in[1]*in[0] + data[5]*in[0]^2 +
      data[6]*in[1]^3 + data[7]*in[1]^2*in[0] + data[8]*in[1]*in[0]^2 + data[9]*in[0]^3 +
      data[10]*in[1]^4 + ...
3) For a three-input polynomial (num_in = 3):
out = data[0] + data[1]*in[2] + data[2]*in[1] + data[3]*in[0] +
      data[4]*in[2]^2 + data[5]*in[2]*in[1] + data[6]*in[2]*in[0] +
      data[7]*in[1]^2 + data[8]*in[1]*in[0] + data[9]*in[0]^2 +
      data[10]*in[2]^3 + data[11]*in[2]^2*in[1] + data[12]*in[2]^2*in[0] +
      data[13]*in[2]*in[1]^2 + data[14]*in[2]*in[1]*in[0] +
      data[15]*in[2]*in[0]^2 + data[16]*in[1]^3 + data[17]*in[1]^2*in[0] +
      data[18]*in[1]*in[0]^2 + data[19]*in[0]^3 +data[19]*in[2]^4 + ...
The coefficients can also be defined by a file by specifying the parameter filename. The file defines the parameter values in Python format, e.g.:
num_in = 1
data = [1.0, 2.0, 1.0]
out output xreal output signal
in input xreal input signals
num_in integer 1 None number of inputs
data real array ‘{0.0} None polynomial coefficients
filename string “” None parameter definition file
« multiply
poly_sel »
