integ_mod :
An integration with modulo operator for xreal-typed signals
The integ_mod primitive computes the time-integral of an xreal-typed input signal in. Its difference from the integ primitive is that it produces a bounded output ranging from offset to offset + modulus via a modulo operation.
As with the integ primitive, the parameters init_value and scale specify the output initial value of the integral and the input scale factor, respectively, the equation governing the output signal out is as follows:
out = modulo(init_value-offset + scale*integral(from 0 to t) of x(t) dt) + offset
| out | output | xreal | output signal |
| in | input | xreal | input signal |
| init_value | real | 0.0 | None | output initial value |
| >scale | real | 1.0 | None | input scale factor |
| modulus | real | 1.0 | None | output modulus |
| offset | real | 0.0 | None | output offset |
