filter_disc_var :
A variable discrete-time filter for xreal-typed signals.
The filter_disc_var
primitive models a discrete-time filter with an xreal-typed input, of which transfer function can be time-varying, controlled by real-typed inputs.
The primitive samples the input in
at the rising edge of the trigger signal trig
and processes the sampled signal with the following z-domain transfer function controlled by the inputs num
and den
to produce the output out
a0 + a1*z^(-1) + a2*z^(-2) + ... + aN*z^(-N) H(z) = ------------------------------------------------ b0 + b1*z^(-1) + b2*z^(-2) + ... + bM*z^(-M)
where the numerator coefficients a0, a1, …, aN are set by the real-typed array input num
(i.e., num[0:N] = ‘{a0, a1, …, aN}) and the denominator coefficients b0, b1, …, bM are set by the real-typed array input den
(i.e., den[0:M] = ‘{b0, b1, …, bM}). The value of the coefficient b0 (i.e. den[0]) must not be zero at all times. The parameters order_num
and order_den
specify the order of the numerator (N) and the order of the denominator (M) of the transfer function, respectively.
If the order of the denominator order_den
is 0 (i.e., M=0), the primitive models a discrete-time filter with a finite impulse response (FIR). Otherwise, the primitive models a discrete-time filter with an infinite impulse response. The parameter init_value
specifies the initial output value of the filter.
out | output | xreal | output signal |
in | input | xreal | input signal |
trig | input | xbit | trigger signal |
num | input | real | numerator coefficients |
den | input | real | denominator coefficients |
order_num | integer | 0 | None | order of numerator |
order_den | integer | 0 | None | order of denominator |
init_value | real | `NaN | None | initial output value |
