filter_disc :
A discrete-time filter for xreal-typed signals.
The filter_disc primitive models a discrete-time filter with an xreal-typed input. The primitive samples the input in at the rising edge of the trigger signal trig and processes the sampled signal with the following z-domain transfer function to produce the output out:
a0 + a1*z^(-1) + a2*z^(-2) + ... + aN*z^(-N) H(z) = ------------------------------------------------ b0 + b1*z^(-1) + b2*z^(-2) + ... + bM*z^(-M)
where the numerator coefficients a0, a1, …, aN are defined by the parameter array num (i.e., num[0:N] = ‘{a0, a1, …, aN}) and the denominator coefficients b0, b1, …, bM are defined by the parameter array den (i.e., den[0:M] = ‘{b0, b1, …, bM}). The value of the coefficient b0 (i.e., den[0]) must not be zero.
If the order of the denominator is 0 (i.e., M=0), the primitive models a discrete-time filter with a finite impulse response (FIR). Otherwise, the primitive models a discrete-time filter with an infinite impulse response. The parameter init_value specifies the initial output value of the filter.
The parameters num, den, init_value can be alternatively defined by a parameter definition file named filename in the following Python format:
num = [a0, a1, a2, ..., aN] den = [b0, b1, b2, ..., bM]
| out | output | xreal | output signal |
| in | input | xreal | input signal |
| trig | input | xbit | trigger signal |
| num | real array | ‘{1.0} | None | numerator coefficients |
| den | real array | ‘{1.0} | None | denominator coefficients |
| init_value | real | `NaN | None | initial output value |
| filename | string | “” | None | parameter definition file |
