We can design various types of filters such as Butterworth, Bessel, Chebyshev I/II, and elliptic filters using SciPy’s signal processing library. Can you show an example of converting the filter coefficients designed this way to the parameters of the XMODEL’s 'filter'
primitive?
Here is an example of designing a Chebyshev-II type low-pass filter from the passband/stopband specifications using the cheb2ord()
and cheby2()
functions from the scipy.signal
library. Please refer to the Scipy documentations (https://docs.scipy.org/doc/scipy-0.14.0/reference/generated/scipy.signal.cheb2ord.html) for more detailed descriptions.
#!/usr/bin/env xmodelpy import scipy.signal import numpy as np # design of low-pass chebyshev-II filter wp = 2*np.pi * 0.9e6 # passband edge frequency (rad/s) ws = 2*np.pi * 1.1e6 # stopband edge frequency (rad/s) rp = 3 # maximum attenuation within pass band in dB rs = 40 # minimum attenuation within stop band in dB N, wn = scipy.signal.cheb2ord(wp, ws, rp, rs, analog=True) z,p,k = scipy.signal.cheby2(N, rs, wn, 'lowpass', analog=True, output='zpk')
And here is an example of designing a Chebyshev-II type band-pass filter:
# design of bass-pass chebyshev-II filter wp = [2*np.pi*1.1e6, 2*np.pi*2.9e6] # passband edge frequency (rad/s) ws = [2*np.pi*0.9e6, 2*np.pi*3.1e6] # stopband edge frequency (rad/s) rp = 3 # maximum attenuation within pass band in dB rs = 40 # minimum attenuation within stop band in dB N, wn = scipy.signal.cheb2ord(wp, ws, rp, rs, analog=True) z,p,k = scipy.signal.cheby2(N, rs, wn, 'bandpass', analog=True, output='zpk')
Similarly, you can also design Chebyshev-I type filters using cheb1ord()
and cheby1()
, Butterworth-type filters using buttord()
and butter()
, and elliptic-type filters using ellipord()
and ellip()
functions. Wikipedia describes the differences between these filter types in details (https://en.wikipedia.org/wiki/Chebyshev_filter).
In the above examples, the z
, p
, k
results store the zero frequencies, pole frequencies, and gain value of the designed linear filter, respectively. There are a few considerations when you use them as the 'poles
', 'zeros
' and 'gain
' parameters for the XMODEL's 'filter
' primitive:
1. The 'poles
' and 'zeros
' parameters list the pole/zero frequency values in Hertz whereas SciPy returns pole/zeros frequencies in rad/s.
2. The real part of the pole/zero frequencies listed in the 'poles
' and 'zeros
' parameters is positive for left-half plane (LHP) poles/zeros and negative for right-half plane (RHP) poles/zeros. For SciPy results, it is negative for LHP and positive for RHP poles/zeros.
3. The 'poles
' and 'zeros
' parameters list the real and imaginary parts of each pole/zero frequency as separate numbers as below. It is because SystemVerilog does not natively support complex numbers:
poles = '{real(fp1), imag(fp1), real(fp2), imag(fp2), ..., real(fpM), imag(fpM)} zeros = '{real(fz1), imag(fz1), real(fz2), imag(fz2), ..., real(fzN), imag(fzN)}
4. The complex poles/zeros listed in the 'poles
' and 'zeros
' parameters must be in exact conjugate pairs.
5. To express a filter transfer function without any zeros, the 'zeros'
parameter should be defined as '{0.0}.
6. For a strictly proper system, the number of poles of a 'filter
' primitive must be greater than the number of zeros. To satisfy this requirement, you may need to add a dummy pole (e.g. a pole at 1THz) that does not affect the filter characteristics.
For example, for z
, p
, k
values shown below:
z = [ -3.72529030e-09+16418754.44763247j -5.23868948e-09-16418754.44763249j 1.92618690e-09 +6800870.76948295j 7.78721962e-11 -6800870.76948295j] p = [ -1075430.76302337+2991438.64240786j -3170099.69183802+1512931.2492777j -3170099.69183801-1512931.2492777j -1075430.76302337-2991438.64240787j] k = (0.01+0j)
The corresponding filter instance may be:
filter #(.gain(0.01), .poles('{171160, 476102, 504537, 240790, 504537, -240790, 171160, -476102, 1e12, 0.0}), .zeros('{0.0, 2613125.9, 0.0, -2613125.9, 0.0, 1082392.2, 0.0, -1082392.2})) filter_inst (.in(in), .out(out));
Note that the pole/zero frequencies are reordered to arrange the complex poles/zeros in conjugate pairs. Also, a dummy pole at a frequency well above the other pole/zero frequencies (1THz) is added in order to keep the filter strictly proper.
Here is one way to convert z
, p
, k
values to gain
, poles
, zeros
parameters:
def sort_pz(p): res = [] for w in sorted(p, key=np.real): f = w / (2*np.pi) if f.imag == 0.0: res += [f.real, 0.0] elif f.imag > 0.0: res += [f.real, f.imag, f.real, -f.imag] return res gain = (k / np.prod(-p) * np.prod(-z)).real poles = sort_pz(-p) zeros = sort_pz(-z) if len(p) <= len(z): poles += [1e12, 0.0] * (len(z)-len(p)+1) if len(z) == 0: zeros += [0.0] print("gain : %g" % gain) print("poles : %s" % ', '.join(['%g' % v for v in poles])) print("zeros : %s" % ', '.join(['%g' % v for v in zeros]))
The attachment is a Python script named 'filter_design.py'
, which can design a filter that satisfies your specifications and display its transfer function using the parameters of the XMODEL 'filter'
primitive. With this script, one can model various common-class filters in XMODEL in a more convenient fashion.
The filter specifications are defined using the script's command-line options. The list of available options and their usages are displayed when you run the script on the command-line with the '-h'
option.
xmodelpy filter_design.py -h
Result:
Usage: filter_design.py [options] Design a common-class filter. Options: -h, --help show this help message and exit -f FREQ_or_FREQ1,FREQ2, --freq=FREQ_or_FREQ1,FREQ2 Critical frequency or frequencies in Hz (default: 1.0). For lowpass and highpass filters, it is a single frequency value defining the cut-off; for bandpass and bandstop filters, it is a pair of frequency values separated by a comma (,) defining the low-side and high-side cut-offs. -n ORDER, --order=ORDER Order of the filter (default: 2). -t FILTER_TYPE, --type=FILTER_TYPE Filter type (choices: lowpass, highpass, bandpass, bandstop); the default is'lowpass'
. -c FILTER_CLASS, --class=FILTER_CLASS Filter class (choices: butter, cheby1, cheby2, ellip, bessel); the default is'butter'
. --rpass=MAX_ATTEN_PASS, --ripple-pass=MAX_ATTEN_PASS Maximum attenuation allowed in passband in dB (default: 3.0); used for cheby1 and ellip filters. --rstop=MIN_ATTEN_STOP, --ripple-stop=MIN_ATTEN_STOP Minimum attenuation required in stopband in dB (default: 30.0); used for cheby2 and ellip filters. --plot, --show-plot Show the bode plot of the designed filter.
The following example illustrates a case of modeling a Bessel-type, fourth-order, low-pass filter with a 1GHz cut-off frequency. With the '--plot'
option, the script displays the transfer function of the filter in Bode plots.
xmodelpy filter_design.py --freq 1e9 --type lowpass --order 4 --class bessel --plot
Result:
*** FILTER PRIMITIVE PARAMETERS: gain : 1 poles : 6.57211e+08, 8.30161e+08, 6.57211e+08, -8.30161e+08, 9.04759e+08, 2.70919e+08, 9.04759e+08, -2.70919e+08 zeros : 0
The next example illustrates a case of modeling an elliptic-type, sixth-order, band-pass filter with 0.1GHz and 1GHz cut-off frequencies. An elliptic filter may have ripples in its passband and stopband responses, and the '--rpass'
option specifies the maximum attenuation allowed in the passband in dBs while the '--rstop'
option specifies the minimum attenuation required in the stopband in dBs.
xmodelpy filter_design.py --freq 0.1e9,1e9 --type bandpass --order 6 --class ellip \ --rpass 3 --rstop 40 --plot
Result:
*** FILTER PRIMITIVE PARAMETERS: gain : 0.0100029 poles : 964446, 1.00503e+08, 964446, -1.00503e+08, 6.5194e+06, 1.10333e+08, 6.5194e+06, -1.10333e+08, 9.54733e+06, 9.94906e+08, 9.54733e+06, -9.94906e+08, 4.35826e+07, 1.71065e+08, 4.35826e+07, -1.71065e+08, 5.33682e+07, 9.03193e+08, 5.33682e+07, -9.03193e+08, 1.39856e+08, 5.48943e+08, 1.39856e+08, -5.48943e+08, 1e+12, 0 zeros : -4.37263e-08, 2.41733e+09, -4.37263e-08, -2.41733e+09, -4.08238e-08, 9.45706e+07, -4.08238e-08, -9.45706e+07, -2.99276e-08, 1.05741e+09, -2.99276e-08, -1.05741e+09, 5.3513e-09, 4.1368e+07, 5.3513e-09, -4.1368e+07, 1.45881e-07, 8.45223e+07, 1.45881e-07, -8.45223e+07, 4.9254e-07, 1.18312e+09, 4.9254e-07, -1.18312e+09
Attachment: filter_design.py
