trig_rise :
A trigger generator for an xreal-typed signal’s rising events.
The trig_rise primitive generates an xbit-typed trigger out when an xreal-typed signal in has the (N+k*P)-th event rising above a given threshold after a specified delay, where k is 0, 1, 2, and so on. The threshold, triggering count N, period P, and delay are defined by the parameters threshold, times, period, and delay, respectively. When the parameter times is less than or equal to 0, the primitive triggers out whenever in rises above the threshold after the delay. This primitive is equivalent to the trig_cross primitive with the direction parameter set to +1.
The xbit-typed trigger out can be used as an input to the measurement primitives to measure the time instants, delays, periods, etc. of the triggering events. The trigger signal is initialized to X and changes to 1 when the first event occurs. The trigger output out then toggles to a different value (0 or 1) whenever a subsequent event occurs.
| out | output | xbit | output trigger |
| in | input | xreal | input signal |
| threshold | real | 0.0 | None | threshold level |
| delay | real | 0.0 | seconds | triggering delay |
| times | integer | 0 | None | triggering count |
| period | integer | 0 | None | triggering period |
