meas_edge :
Measurement of the time instants of an xbit-typed signal’s transition events.
The meas_edge
primitive measures the time instants when an xbit-typed signal in
has the (N+k*P)-th transition after a specified delay, where k is 0, 1, 2, and so on. The output is a real-typed value indicating the absolute time of each event. The triggering count N, period P, and delay are defined by the parameters times
, period
, and delay
, respectively. When the parameter times
is less than or equal to 0, the primitive updates the measurement whenever in
has a transition after the delay. The parameter direction
specifies whether the primitive detects the rising events only (+1), falling events only (-1), or both (0).
out | output | real | measurement output |
in | input | xbit | input signal |
direction | integer | 0 | None | crossing direction |
delay | real | 0.0 | seconds | triggering delay |
times | integer | 0 | None | triggering count |
period | integer | 0 | None | triggering period |
